Kubota T2290 Belt
sivicman
Does anyone know if a aftermarket belt is available for the RCK48P-90T mower deck? Also is there a shop manual available for the T2290? I searched the internet, and the only belt I was able to find was the OEM belt. (K5186-36710)
Thanks
There are several aftermarket available just use the PN and do a search of the net.
Now the K5186-36710 is a 5/8 x 149.5 belt.
One option is to go a D&D PowerDrive 5423 belt which is a 5/8 x 150
sivicman
How were you able to find the dimensions of the OEM belt? That will give me a starting point to look at Gates etc. Thanks for the Amazon link too. The OEM belt is $100 at the dealer. Now I have to look for aftermarket metal pullies, and get rid of the plastic ones. Thanks
Wait a minute here I didn't look close enough to cross I received. My fault due all the hell I been thru the last two weeks with computer problems.
The dimension I gave are for the K5579-36710 belt and not for the K5186-36710. The K5186-36710 appears to be a B174 Kevlar belt 5/8" x 177".
K5186-36710 "BELT MOWER 48, B-174 KC"
Sorry for the miss info as I should known it was on the short side for that crazy belt setup.
I keep hunting on this end when I get to the shop.
sivicman
Thanks for the update. I wonder if I am able to find a Kevlar belt in aftermarket? This is not a V-belt I take it?
I believe they would have label it as a BB if it was a hex belt. And according to the IPL all the idlers are Flat type and only the spindle pulleys and the pulley at the engine are V type.
Now for the 5/8 x 177 here is a few possibles.
  • Hustler 797720
  • Oregon 15-019
  • Stens 265-711
  • Rotary 12322
  • Toro/Exmark 114-8154
  • PIX P-797720
Check out Amazon for some others based on these PNs. Those listed above all have list prices in the same ballpark as the Kubota one but a few aftermarkets on Amazon are about half that.
Meanwhile I am going the grocery store and hope I have a little left over for fuel.
jaxontheweb
Thanks
Check Amazon and reference the Make, Size and Model of the unit and there are usually several choices. At least on my Dixie Chopper they have been right on and have decent prices.
Jack
sivicman
I looked underneath at the belts, and both are V-belts.
DWSarow
Do you happen to be on another forum?It's 'Orange Tractor Talks'?,Maybe someone over there can help!Good luck.If you do go there,check,Service,Repair&Maintenance.About the third line down,ultimate help,coachgeo
