Ric
- May 7, 2010
- Threads
- 142
- 5,765
This is a little off the subject of how to lift ---
Why own a tractor for mowing that requires lifting to work on the mower deck ? The Deere 318 and other Deere models I've seen allow easy disconnect and slide deck out. The Gravely I had was easy to disconnect and drive off and drive back over. The Ventrac disconnects quickly and the deck will flip up for service.
Why would the designers require lifting the machine to service the mower deck ? :thumbdown:
Just my humble question ???? :confused2:
Why would the designers require lifting the machine to service the mower deck? Answer they Don't.
It's all about money and what most people want, can afford or are willing to pay for a mower. Most people buy there mowers from Home Depot or Lowes or maybe even Tractor Supply and I'll add Sears just for fun, they're the people the designers call home owners. Now the typical home owner is going to mow his 2 to 3000 sq.ft lot around his 1700 sq.ft house maybe three times a month and change the oil one time a year and in two or three years replace the mower with a new one and the designer :licking: he's making money hand over fist.
As far as lifting a mower goes and what you use to lift the mower I think comes down to how you use the mower. I have my mower on the MoJack at least three times a week, cleaning , Greasing, and changing blades and with the MoJack it's minutes and I'm
done.:thumbsup:
